[postgis-devel] Issue 60 in postgis: Tarball of 1.3.3 has object files and .svn directories; impossible to build without clean on MacPro
codesite-noreply at google.com codesite-noreply at google.com
Tue Oct 14 14:23:22 PDT 2008
Issue 60: Tarball of 1.3.3 has object files and .svn directories;
http://code.google.com/p/postgis/issues/detail?id=60
Comment #1 by xander:
FYI, the exact error from the OS X linker is: file is not of required
architecture
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
