[postgis-devel] Is ST_Shift_Longitude supposed to work with MultiPoints?
Obe, Regina robe.dnd at cityofboston.gov
Thu Oct 16 19:21:01 PDT 2008
Can someone test this on a 1.3.4 install.  Unfortunately I don't have one handy at the moment.  I tried on a 1.3.3 install
SELECT ST_Shift_Longitude(ST_GeomFromText('MULTIPOINT(-118.58 38.38,-118.60 38.329,-118.614 38.281)'))
And got this error
ERROR:  lwgeom.c:723: unknown geom type: 4
Seems to work okay for line strings and multi linestrings and geometry collections.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081016/2b8d6f3c/attachment.html>
