[postgis-devel] 1, dot, 3 dot 4!
Obe, Regina robe.dnd at cityofboston.gov
Fri Oct 17 06:36:29 PDT 2008
Paul,
Hmm scratch this thought - I don't think it will help much on further
thinking
'SELECT $1 && ST_Expand($2,$3) AND $2 && ST_Expand($1,$3) AND
(_ST_DWithin($1, $2, $3) or ST_Distance($1,$2) < $3)'
this is a bit of a bummer if this is the case, since this is a somewhat
important use-case for me.
I'll need to test further to verify my assumption.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
