[postgis-devel] 1, dot, 3 dot 4!
Paul Ramsey pramsey at cleverelephant.ca
Sun Oct 19 14:14:17 PDT 2008
Yes, this has already been fixed on trunk, here's a patch against 3.0,
let me know if it helps.
P.
On Sun, Oct 19, 2008 at 8:37 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Obe, Regina wrote:
>> Paul,
>> Sounds like a plan.
>> Regarding the kml failure.  I tried to be lazy by
>> 1) copying my Open SUSE 11 vm.
>> 2) downgrade to 1.3.3
>> 3) ran make check and it failed on kml check again.  So I assume the kml
>> thing is nothing to worry about.
>> (But oops wait a minute reads 1.3.3 with GEOS 3.1.0.  I assume KML doesn't
>> use GEOS so that wouldn't affect things, but just to be sure, I tried to
>> downgrade to geos 3.0.0 and couldn't because got this error during compile
>> DoubleBits.cpp: In constructor
>> 'geos::index::quadtree::DoubleBits::DoubleBits(double)':
>> DoubleBits.cpp:94: error: 'memcpy' was not declared in this scope
>> make[3]: *** [DoubleBits.lo] Error 1
>> make[3]: Leaving directory `/projects/geos-3.0.0/source/index/quadtree'
>> make[2]: *** [all-recursive] Error 1
>> make[2]: Leaving directory `/projects/geos-3.0.0/source/index'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory `/projects/geos-3.0.0/source'
>> make: *** [all-recursive] Error 1
>> 4) Okay that didn't work so I went to
>> http://download.osgeo.org/geos/geos-3.0.2.tar.bz2  - still no go
>>  g++ -DHAVE_CONFIG_H -I. -I. -I../../../source/headers
>> -I../../../source/headers/geos -I../../../source/headers -g -O2
>> -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long -MT DoubleBits.lo -MD -MP
>> -MF .deps/DoubleBits.Tpo -c DoubleBits.cpp  -fPIC -DPIC -o
>> .libs/DoubleBits.o
>> DoubleBits.cpp: In static member function ?static double
>> geos::index::quadtree::DoubleBits::powerOf2(int)?:
>> DoubleBits.cpp:51: error: ?memcpy? was not declared in this scope
>> ?geos::index::quadtree::DoubleBits::DoubleBits(double)?:
>> DoubleBits.cpp:94: error: ?memcpy? was not declared in this scope
>> make[3]: Leaving directory `/projects/geos-3.0.2/source/index/quadtree'
>> make[2]: Leaving directory `/projects/geos-3.0.2/source/index'
>> make[1]: Leaving directory `/projects/geos-3.0.2/source'
>> Not quite sure what the above errors mean? Probably that compiling should
>> be left to people who know what they are doing.  I think I was able to
>> compile these on my OpenSUSE 10.5, but I'll have to double check.  I can
>> only wildly guess this is all due to me using a dev version of gcc.
> Yup - it's a gcc-4.3-ism. It seems as if they've made the distinction
> between C and C++ header files a lot more strict, and the DoubleBits.cpp
> includes a C file rather than a C++ file. The solution, as seen in the SVN
> trunk version, is to #include <cstring> below #include <string> in
> DoubleBits.cpp.
> If this works, I'd drop a separate email to geos-devel asking for the fix to
> be backported to the 3.0 branch.
>> I guess this is what I get for trying to live on the edge virtually.  Good
>> thing I don't try to do these things in real life :)
> Heh, setting up a build environment is always the hardest part since you
> generally need a lot more dependent libraries and tools to build anything
> than you do to run it. But once it's there, it generally works very well so
> stick with it :)
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081019/8bf167ff/attachment.obj>
