[postgis-devel] isvalid(geom), but st_ashexewkb(geom, 'NDR')::geometry fails
David Fuhry
dfuhry at acm.org
Fri Oct 24 08:25:26 PDT 2008
Regina,
Yeah, I agree that the WKT is not valid. The real question is, is
the WKB valid? If not, isvalid() should return false. If so, the
parser should parse it without error.
ST_GeomFromText('MULTIPOLYGON EMPTY') returns a different geometry
from mine. Adding the srid makes it a little closer, but not the same.
Both of these are correctly identified as st_isempty(), although mine
is not.
db=> select st_geomfromtext('MULTIPOLYGON EMPTY');
st_geomfromtext
010700000000000000
(1 row)
db=> select setsrid(st_geomfromtext('MULTIPOLYGON EMPTY'), 3785);
setsrid
0107000020C90E000000000000
(1 row)
Thanks,
Dave
Obe, Regina wrote:
> David,
> I don't think that is valid WKT syntax for an EMPTY multipolygon. If I
> try to stuff that in via ST_GeomFromText it returns invalid geometry.
> Not sure how you got that in there.
> It should be
> SELECT ST_GeomFromText('MULTIPOLYGON EMPTY');
> On 1.3.3 and 1.3.4SVN - when I do this - I get the below which is also
> kind of odd. I would have expected it to maintain the empty polygon.
> SELECT ST_IsValid(the_geom), ST_AsText(the_geom), ST_IsEmpty(the_geom),
> ST_AsEWKT(the_geom) FROM (SELECT ST_GeomFromText('MULTIPOLYGON EMPTY')
> As the_geom) As foo ;
> st_isvalid | st_astext | st_isempty |
> st_asewkt
> t | GEOMETRYCOLLECTION EMPTY | t | GEOMETRYCOLLECTION
> EMPTY
> (1 row)
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net on behalf of David Fuhry
> Sent: Thu 10/23/2008 11:28 PM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] isvalid(geom), but
> st_ashexewkb(geom,'NDR')::geometry fails
> I have an empty multipolygon which isvalid(), but which the parser
> throws "ERROR: geometry requires more points" on. Is this a bug in
> isvalid(), or in the parser? Interestingly, st_isempty() returns false.
> db=> select geom from tt;
> geom
> 0106000020C90E00000100000001030000000100000000000000
> (1 row)
> db=> select st_astext(geom) from tt;
> st_astext
> MULTIPOLYGON(( EMPTY))
> (1 row)
> db=> select isvalid(geom) from tt;
> isvalid
> t
> (1 row)
> db=> select st_ashexewkb(geom,'NDR')::geometry from tt;
> db=> select st_isempty(geom) from tt;
> st_isempty
> f
> (1 row)
> db=> select version(), postgis_version();
> version
> | postgis_version
> PostgreSQL 8.3.1 on i486-pc-linux-gnu, compiled by GCC cc (GCC) 4.2.3
> (Debian 4.2.3-4) | 1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> (1 row)
> Thanks,
> Dave
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> * The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant
> to Massachusetts law. It is intended solely for the addressee. If you
> received this in error, please contact the sender and delete the
> material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
