[postgis-devel] 1.3.4rc1
Courtin Olivier olivier.courtin at camptocamp.com
Mon Oct 27 01:38:02 PDT 2008
On Oct 26, 2008, at 10:13 PM, Mark Cave-Ayland wrote:
Mark,
>> Okay, I've finally found a few moments to test on Win32.
>> Compilation goes
>> fine, but regression blows up big style on the geojson test for
>> which I've
>> attached the diff :(  It seems to be precision related, but there
>> must be
>> something different in the code since the problem doesn't occur at
>> all in
>> the rest of the tests.
I've didnt read that mail sorry for that ! :(
> I've spent some time today looking at this and the problem is a
> symptom of different floating point precision(s) and the use of the
> %f format specifier.
> The first thing to note is that the differences in floating point
> implementations will always be present, no matter what we try and
> do. The trick, of course, is to restrict our regression tests to the
> lowest common precision denominator that will pass on all platforms.
> Currently the geojson code format identifiers look like this: %.*f
> where the * is used to indicate the number of decimal places. Now
> unfortunately this is incorrect because the precision of the
> floating point answer is related to the size of the mantissa (and
> hence the number of significant figures) rather than the number of
> decimal places.  So depending upon whether the calculation is done
> in hardware or software, the compiler options and even program
> order, the resulting output is likely to be different.
> The double-precision IEEE floating point format specifies a 64-bit
> number with a 53-bit mantissa, which translates into approximately
> 14 significant figures.
Ok thanks to this,
i've still a lot to learn in portable C programming...
> So in order to solve this, I'd like to propose changing the meaning
> of the precision parameter from decimal places to significant
> figures, and changing the geojson output formats to %*f with a
> maximum precision of 14.
> In my testing here, this gives identical results between gcc and
> MingW for 99.9% of cases, with the small 0.1% being caused by MingW
> adding a trailing "0" to the output when rounding in some cases. I
> would suggest that if there are cases like this in the regression
> tests after conversion then we simply alter the input coordinates to
> prevent this from happening.
> So I'd like to go ahead and do this to 1.3 branch / trunk so that we
> can cleanly pass regression tests on at least gcc/msvcrt in order to
> get 1.3.4 out of the door. Anyone have any major objections?
Some thoughts about that:
- On the whole export functions in PostGIS 1.3 situation is now as this:
   ST_assvg -> %.*f
   ST_asgeojson -> %.*f
   ST_askml -> %.*g
   ST_asgml -> %.*g
%.*g is not really usefull, as the scientific notation is not widely
supported by client applications,
and as you experiment and report %.*f is not portable !
Commons Uses Case (at least for me) are the following:
Round planar geometic data to avoid sub meters precision:
SELECT st_asgeojson(geometryfromtext('POINT(11342340.345678912
2139658548.3248234832)', -1), 0);
{"type":"Point","coordinates":[11342340,2139658548]}
Handle precision on Decimal Degree data between 3 and 6 digits upon
precision needed:
SELECT st_asgeojson(geometryfromtext('POINT(40.345678912
48.3248234832)', 4326), 5);
  {"type":"Point","coordinates":[40.34568,48.32482]}
So my question is: Is there a way to:
-> keep the previous use cases
-> have the same behaviour with all the exports functions
Olivier
