[postgis-devel] Issue 63 in postgis: ST_Max_Distance is not yet implemented?
codesite-noreply at google.com codesite-noreply at google.com
Mon Oct 27 11:51:00 PDT 2008
Issue 63: ST_Max_Distance is not yet implemented?
http://code.google.com/p/postgis/issues/detail?id=63
New issue report by robe.... at cityofboston.gov:
What steps will reproduce the problem?
SELECT ST_Max_Distance(ST_GeomFromText('LINESTRING(1 0, 3 0)'),
ST_GeomFromText('LINESTRING(3 0, 5 0)'))
What is the expected output? huh I think 4
What do you see instead?
ERROR:  This function is unimplemented yet
********** Error **********
SQL state: XX000
What version of the product are you using? On what operating system?
Windows - "POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
2007" USE_STATS"
I think I tried on OpenSUSE 11 1.3.4 SVN and got the same unsatisfying
answer.  I'll have to double-check that.
Please provide any additional information below.
I think the trunk lwpostgis.sql.in.c has this comment
Maximum distance between linestrings. 2d only. Very bogus.
-- Availability: 1.2.2
And I thought it did something way back yander, but could have been my
imagination or it was removed because as the comment says its bogus?
Issue attributes:
	Status: Accepted
	Owner: robe.... at cityofboston.gov
	Labels: Type-Defect Priority-Medium
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
