[postgis-devel] Does ST_Max_Distance work on anyone's install
Obe, Regina robe.dnd at cityofboston.gov
Thu Oct 30 10:46:39 PDT 2008
Thanks strk.  A may consider it attempting it when I get my C skills more beefed up and
I am not so over-worked with other projects, if someone else doesn't fix it before then.
Regina
-----Original Message-----
Sent: Thu 10/30/2008 1:38 PM
To: Obe, Regina
Cc: PostGIS Development Discussion
Subject: Re: [postgis-devel] Does ST_Max_Distance work on anyone's install
On Wed, Oct 29, 2008 at 01:51:41PM -0400, Obe, Regina wrote:
> Ah okay I agree with Strk on that one.
>  For the example he gave I would expect
> it to return 10 too since I think the common use case would be for example
> Given a road a and road b -- what's the furthest that anyone would need to trek
> (excluding routing obstacles)  from anywhere on road a to get to anywhere on road b.
> Hmm I wonder how much effort it would be to fix it.  I guess strk gave up on it
> so that would mean I am probably  too stupid to attempt it.  Pity though.
Hey, I was busy in a HWGEOM to LWGEOM transaction,
wasn't really time to do such big things !
I wish you good luck :)
--strk;
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081030/ee949af0/attachment.html>
