[postgis-devel] st_dwithin, st_within, st_dcompletlywithin
Paragon Corporation lr at pcorp.us
Tue Oct 7 10:11:47 PDT 2008
Nicklas,
Congratulations on the new baby!  Is it a boy or girl?
I'm okay with you just adding this to the current ticket since I agree they
are all related.  Probably best to wait for Paul, Kevin, or Mark to voice
any issues/complaints, but I can't think of any.
Thanks,
Regina
  _____
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
nicklas.aven at jordogskog.no
Sent: Tuesday, July 07, 2009 8:16 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] st_dwithin, st_within, st_dcompletlywithin
I think ST_DFullyWithin sounds great.
Is it ok if I put this to in ticket #137. In the code they are all close
related, st_distance, st_max_distace, st_shortestline, st_longestline,
st_dwithin, st_dfullywithin
I have a patch for the trunk that seems to work, but I haven't tested more
than randomly. I will try to build cunit-tests but I think it is difficult
to get the make check thing work at all. In windows I get som problems and
in ubuntu I get permission-problems. I'm new to Linux.
I also just have become a father :-) two weeks ago so my sparetime for
learning new things has drastically decreased.
/Nicklas
2009-07-07 Paragon Corporation wrote:
Paul and Nicklas,
>I think we had suggested calling it ST_DFullyWithin or maybe that was my
>idea.
>http://trac.osgeo.org/postgis/ticket/20
>Though I guess we closed this out when we put the short circuit in for
>ST_DWithin. We probably should resurrect or add it as a separate ticket.
>Nicklas since you are working on it, you want to add it as a trac item.
>Thanks,
>Regina
>-----Original Message-----
>[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
>Ramsey
>Sent: Monday, July 06, 2009 7:23 PM
>It gets even more confusing if you note that some members of the WFS
working
>group insist that the semantics of the WithinDistance OGC filter op are the
>semantics of your proposed function, rather than the semantics of dwithin.
>P
>On Mon, Jul 6, 2009 at 4:19 PM, wrote:
>> Hallo
>> This is a semantic question.
>> I'm working with the new functions st_shortestline etc.
>> I found that we can get another new function for free when we have
>> implemented st_max_distance. By using the max-calculation instead of
>> min-calculation the same way as st_dwithin, we insead get
>> "st_dcompletlywithin" the function returns true if the maximum
>> distance between the geometries is shorter than the third input.
>> My question is (beside the question if this is something useble), what
>> to call the function. I think it easily can be confusing. I mean,
>> st_within and st_dwithin is two quite similar names wich is ok because
>> they don't really relate to eachother in what they do, but if we add a
>> function that do the same as st_dwithin but whith the difference that
>> the geometries has to be completly inside the given distance of
>> eachother, maybe we risk making it confusing. I guess
>> st_dcompletlywithin is maybe the most describing, but very long.
>> Greetings
>> Nicklas
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081007/68bd9a37/attachment.html>
