[postgis-devel] [PostGIS] #183: ST_LineToCurve gives getPoint4d_p offset error
PostGIS trac at osgeo.org
Tue Oct 7 13:16:07 PDT 2008
  Reporter:  robe     |       Owner:  robe
      Type:  defect   |      Status:  assigned
  Priority:  low      |   Milestone:  postgis 1.3.7
 Component:  postgis  |     Version:  1.4
Resolution:           |    Keywords:
Comment (by mcayland):
 Okay. Looks like the curve conversion code needs to peek one point ahead
 to determine the type of the next segment, and of course if you end your
 curve at the end of your set of points then this will fail.
 Can you try the attached patch which seems to resolve this for me?
 ATB,
 Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/183#comment:8>
