[postgis-devel] [PostGIS] #219: Run 'make check' without needing 'make install' first
PostGIS trac at osgeo.org
Tue Oct 7 17:51:52 PDT 2008
 Reporter:  pramsey      |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  postgis 1.5.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
 It seems a bit counterintuitive that running 'make check' requires you to
 'make install' first. Attached for comment is a patch that allows you to
 run 'make check' on your local copy of libpostgis.so without installing it
 first.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/219>
