[postgis-devel] [PostGIS] #180: History table example implementation
PostGIS trac at osgeo.org
Tue Oct 7 20:50:12 PDT 2008
  Reporter:  pramsey      |       Owner:  pimpaa
      Type:  enhancement  |      Status:  assigned
  Priority:  medium       |   Milestone:  postgis 1.5.0
 Component:  postgis      |     Version:
Resolution:               |    Keywords:
Comment (by pimpaa):
 Well, to change everyting to a dif schema inst hard at all.
 This is what i need, concerning user input. My first tought was to have a
 diferent schema, 'history'.
 This is a discussion that i would like to initiate. I'm here to help :D.
 history tables will get big pretty fast, since each update they create a
 new record. a new fucntion that i'm planning (and i need help, with
 sugestions) is to create indexes to the history_table. It´s little
 improvemente, but its a nice improvement. It´s not possible to recreate
 the indexes that are used on the original table because it will implicate
 in a primary key index in the "id" field.
 The "like" command provides this functionlaity, but i dont think its all
 that useful. It will cause more trouble then good.
 to pramsey: the spatial constraints are perhaps not needed, since they ARE
 veryfied in the parent table. i'll look into that.
 anyhow! i would like suggestions to improve the schema, tables, and
 everything.
 specifying a schema is useful, and not specifying is useful too, so we
 need to ponderate the benefits on over another.
 as i said, im open to suggestions, and theres is tons of improvements over
 this code. im just a begginer.
 thanks to all that had the patiete to go trought it and evaluate it.
 george
Ticket URL: <http://trac.osgeo.org/postgis/ticket/180#comment:12>
