[postgis-devel] [PostGIS] #112: ST_CurveToLine sometimes crashes server
trac at osgeo.org
Tue Oct 7 22:12:15 PDT 2008
Reporter: robe | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: postgis 1.4.0
Component: postgis | Version: 1.3.X
Resolution: fixed | Keywords:
Changes (by mcayland):
* status: reopened => closed
* resolution: => fixed
Comment:
Fixed in 1.4 in r4271 and trunk in r4272. Colinearity in the circle points
was detected, however the check was missing for the NULL pointer being
returned in this case. If the points are detected as colinear, then the
current behaviour is to simply append the circle points to the LINESTRING
as standard points.
Again, I don't feel the need to backpatch to 1.3 due to the existing
curve-related bugs that won't get fixed in that branch.
ATB,
Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/112#comment:12>
