[postgis-devel] [PostGIS] #219: Run 'make check' without needing 'make install' first
PostGIS trac at osgeo.org
Wed Oct 8 09:14:26 PDT 2008
  Reporter:  pramsey      |       Owner:  pramsey
      Type:  enhancement  |      Status:  closed
  Priority:  medium       |   Milestone:  postgis 1.5.0
 Component:  postgis      |     Version:  trunk
Resolution:  fixed        |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I've committed the one allowing top-level run and also added dependency to
 build the source sql file (and as side-effect the actual library).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/219#comment:2>
