[postgis-devel] What's the point of this exercise in intersects?
Obe, Regina robe.dnd at cityofboston.gov
Mon Sep 8 17:14:23 PDT 2008
You guys are going to hate me.  My C'est La Vie was short-lived.  It just occurred to me
unless my understanding of how PostgreSQL and PostGIS works is wrong.
Even if you don't have indexes on your geometry isn't the implicit
&& going to force a bounding box check still and since operators have higher priority, wouldn't that still be run before the
_ST_Intersects etc. The check in intersects etc. doesn't even work if there is no bounding box around the geometry, does a on the fly buffer ever have a bounding box?
Explain that to me Mark and perhaps I can be blissful again.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Obe, Regina
Sent: Mon 9/8/2008 8:00 PM
To: PostGIS Development Discussion
Subject: RE: [postgis-devel] What's the point of this exercise in intersects?
> There are cases where the geometry is generated within the query, such
> as by buffering and the like, where an index cannot be created.  There
> are cases where a sequence scan is selected by the scheduler for
> whatever reason (selectivity of other constraints, size of table,
> outdated stats...).  And there's the case where the user didn't build an
> index.  Given the low overhead these shortcuts introduce, I would prefer
> to leave them in order to cover these sorts of cases.
> Mark Leslie
Thanks Mark - Now I feel C'est la vie too :)
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080908/107735fa/attachment.html>
