[postgis-devel] What's the point of this exercise in intersects?
Obe, Regina robe.dnd at cityofboston.gov
Tue Sep 9 07:41:29 PDT 2008
Mark,
>  Why can't you be happy with bliss?
I feel a little bit more blissful now.  Thanks Mark.
Eternal Bliss is so boring.  Life is about misery and overcoming it or
making yourself more miserable.  It is all about having non-zero
derivatives :)
>  As for the generated geometries, they are automatically generated in
a
> number of cases, which are documented somewhere in the code.  I don't
> recall what they all were were, but they included such vague cases as,
> 'sufficiently complex geometries,' as well as some quite specific
ones,
> such as 'never on points'.
Hmm so in these cases I presume this redundancy may be useful?  Although
in these cases do
we make sure to add a bbox to the geometry.  Looking at the comment of
the code - it seems to suggest
the BBOX short-circuit would happen only if there already existed a bbox
attached to the geometry, but I am
not sufficiently skilled in my C reading to determine if the code
completely matches the comment and whether these  generated geometries
you refer to have bboxes.
I'm still questioning how cheap of a call this is though - looks
harmless but you never know.
Maybe I'll do some large data runs of point in Polys with and without to
see how much of a difference it makes.
If it were an index call, it would be cheap for sure, but
its not, so I can only assume its worse or at best as good as doing a
non-indexed && on a set of geometries you know will already return true.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
