[postgis-devel] Re: [postgis-users] PDF version of manual?
Kevin Neufeld kneufeld at refractions.net
Thu Sep 11 08:47:48 PDT 2008
Great.  Thanx Mark.
Curious. <inlinegraphic> is not a DocBook standard?
Ah.  I see it's been deprecated in v5.0.  For some reason I thought we
were complying with version v4.5.
If that's the case, we would need to change the first line in the
postgis.xml document appropriately, no?
<!DOCTYPE book PUBLIC "-//OASIS//DTD DocBook XML V4.3//EN"
"http://www.oasis-open.org/docbook/xml/4.3/docbookx.dtd"
You mentioned you tried xmlroff to generate the pdf but it didn't fair
well.  Previously, Paul generated his nice version that closely matches
the new html stylesheet using XSL-FO and Adobe Fop.  I haven't been able
to reproduce that yet though.
Cheers,
Kevin
Mark Cave-Ayland wrote:
> Kevin Neufeld wrote:
>> Yeah, it looks like things got a little jumbled with the new
>> documentation shuffle.
>> I've reinstated the link on the documentation webpage to an older pdf
>> I found (version 1.3.2).
>> (http://postgis.refractions.net/docs/postgis.pdf ).  In my spare time,
>> I'll work to update the postgis autobuild process to update this file
>> on a regular basis.
>> Cheers,
>> Kevin
> Okay, I've just committed some fixes to the documentation Makefile and
> docbook source to enable PDFs to be generated once again. "make
> postgis.pdf" in the documentation directory should now churn out a nice
> PDF.
> The most important thing to note is that OpenJade is a lot more strict
> than xsltproc on its DocBook input source. In particular I had to change
> the following points:
> - Remove the class attribute from the <inlinegraphic> element (according
> to the DocBook standard, it doesn't exist anyway)
> - <note> elements cannot contain CDATA (I got around this by wrapping
> the content in a further set of <para> elements)
> - OpenJade doesn't like empty sections in the documentation; hence I
> added some <para> elements containing simply an   character
> In response to my previous email, I did try using xmlroff based on the
> gnome toolset to generate the documentation, but I didn't think the end
> result was as good as the OpenJade output - if other people wish to
> experiment, feel free, but my feeling is we should stick with OpenJade
> for the time being.
> Things to resolve:
>     - Some parts of the documentation appear in red?
>     - Inline graphics don't appear to be included (may be a case of
>     moving the images/ subdirectory?)
> But in the meantime, I hand this back over to the hardworking
> documentation authors :)
> ATB,
> Mark.
