[postgis-devel] Issue 52 in postgis: Link SRID wordto Wikipediaarticle about SRID
Obe, Regina robe.dnd at cityofboston.gov
Mon Sep 15 16:40:47 PDT 2008
> Personally, I like the idea of having links right in the example.  It's
> like reading a Wikipedia article where all words that require further
> explanation have links to other articles.  Having lots of cross
> references make for easy learning.  But that's just my two cents.
I see what you mean. I guess I was thinking the cases where SRID is not mentioned but we have
4326 (I suppose we would just link the number, so you are right it is not as invasive in thought as I was thinking)
 I'm all for that then - but as you said no xref allowed in preformatted blocks? :(
> So, in any event, we should add the upgrade to the
> Spatial_Ref_Sys Table section (4.2.1) to our TODO list.
Okay I'll add to list.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080915/eee5077e/attachment.html>
