[postgis-devel] ST_Expand unexpected behavior
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Sep 19 08:34:05 PDT 2008
David Fuhry wrote:
> Oracle spatial returns a four-ordinate rectangle:
> SQL> select sdo_aggr_mbr(geom) from v_parcel;
> SDO_GEOMETRY(2003, 41100, NULL, SDO_ELEM_INFO_ARRAY(1, 1003, 3),
> SDO_ORDINATE_ARRAY(2210526.17, 645599.584, 2222040.84, 655437.454))
> Although the returned geometry's sdo_gtype is that of a 2D polygon, the
> fact that it has only four ordinates means that it should be considered
> to be a 2D bounding box.  This is mentioned in the docs, but the online
> 11g doc server is unresponsive, so I can't send a link.
> Thanks,
> Dave
Hmmm I see. So that's almost equivalent to the PostGIS BOX3D type which
is just for bounding boxes. I'd be interested to the same on other
spatial databases such as Informix and SQL Server 2008 just to see how
other people have interpreted the spec.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
