[postgis-devel] Issue 35 in postgis: Comments on Postgis Functions
codesite-noreply at google.com codesite-noreply at google.com
Mon Sep 22 08:16:30 PDT 2008
Issue 35: Comments on Postgis Functions
http://code.google.com/p/postgis/issues/detail?id=35
Comment #5 by dane.springmeyer:
Regina,
I'm stuck momentarily trying to rebuild my libxslt since I got this error
with your command to build the sql:
springmeyer:doc spring$ xsltproc -o postgis_comments.sql
xsl/postgis_comments.sql.xsl reference_new.xml
compilation error: file xsl/postgis_comments.sql.xsl line 2 element
stylesheet
xsl:version: only 1.0 features are supported
So, I tried the  'postgis_comments.sql' you posted to postgis-dev and it
looks good.
However, I did notice a few things:
1) There are windows line endings that show up as 'r''s in my psql terminal
(see below, but which won't be a problem I figure when I can build it
myself).
2) In the example below shouldn't the first ST_AsKML(geometry ) entry (as
opposed to ST_AsKML(geometry , integer )) not list the Second argument
explanation in the comments?
beaver=# \dd *kml*
                                                        Object descriptions
  Schema |   Name   |  Object  |
Description
  public | st_askml | function | args: g1 - Return the geometry as a KML
element. Second argument may be\r
                               :             used to reduce the maximum
number of significant digits used in\r
                               :             output (defaults to 15).
  public | st_askml | function | args: g1, max_num_decimal_digits - Return
the geometry as a KML element. Second argument may be\r
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
