[postgis-devel] Minimum number of points in a POLYGON ring?
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Sep 22 08:32:01 PDT 2008
David Fuhry wrote:
> Oracle Spatial itself does no validity checks:
> SQL> create table tt as select sdo_geometry(2003, null, null,
> sdo_elem_info_array(1,1003,3), sdo_ordinate_array(0,0, 0,1, 1,1, 1,0,
> 0,0)) as geom from dual;
> Table created.
> SQL> update tt a set a.geom.sdo_ordinates = sdo_ordinate_array(0,1,2);
> 1 row updated.
> SQL> commit;
> Commit complete.
> SQL> select geom from tt;
> SDO_GEOMETRY(2003, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 1003, 3),
> SDO_ORDINATE_ARRAY(0, 1, 2))
Thanks David. I have one more question: what happens if you try and
return the area of your open polygon above?
Many thanks,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
