[postgis-devel] Issue 54 in postgis: segfault with st_numgeometries when --enable-debug
codesite-noreply at google.com codesite-noreply at google.com
Tue Sep 23 13:05:31 PDT 2008
Issue 54: segfault with st_numgeometries when --enable-debug
http://code.google.com/p/postgis/issues/detail?id=54
Comment #3 by mark.cav... at siriusit.co.uk:
Okay, I've finally committed a solution for this to SVN trunk. Please do
an "svn up"
followed by a complete "make clean" / "make install" cycle since I had to
refactor
the liblwgeom memory API a little in order to make this work.
Paul, can you confirm that this resolves the issue for you?
ATB,
Mark.
Issue attribute updates:
	Status: Started
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
