[postgis-devel] Issue 21 in postgis: locate_along_measure: wrong values, invalid data ?
codesite-noreply at google.com codesite-noreply at google.com
Tue Sep 23 14:15:01 PDT 2008
Issue 21: locate_along_measure: wrong values, invalid data ?
http://code.google.com/p/postgis/issues/detail?id=21
Comment #8 by l... at rosinak.at:
the problem seems that with the m-value given and the way
clip_seg_by_m_range() works
two result elements (instead of one) are created.
i hope the attached fix is acceptable, it does the right thing for me.
Richard
	issue-21-patch.diff  984 bytes
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
