[postgis-devel] Issue 21 in postgis: locate_along_measure: wrong values, invalid data ?
codesite-noreply at google.com codesite-noreply at google.com
Thu Sep 25 15:29:02 PDT 2008
Issue 21: locate_along_measure: wrong values, invalid data ?
http://code.google.com/p/postgis/issues/detail?id=21
Comment #14 by l... at rosinak.at:
Hi Mark,
you are right. I assume that I messed up my codebase a little.
I can reproduce your results with a clean svn checkout and with the
postgis-1.3.3.tar.gz release package.
Kind regards,
Richard
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
