[postgis-devel] Issue 21 in postgis: locate_along_measure: wrong values, invalid data ?
codesite-noreply at google.com codesite-noreply at google.com
Tue Sep 30 06:42:07 PDT 2008
Issue 21: locate_along_measure: wrong values, invalid data ?
http://code.google.com/p/postgis/issues/detail?id=21
Comment #16 by mark.cav... at siriusit.co.uk:
Hi Richard,
I've applied my patch from above to both the 1.3 and trunk versions, and
included
your enhanced regression tests to monitor these conditions in future.
Thanks for your
help with this bug report.
Many thanks,
Mark.
Issue attribute updates:
	Status: Fixed
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
