[postgis-devel] [WKT Raster] Random bands truncation
Mateusz Loskot Mateusz.Loskot at cadcorp.com
Wed Apr 1 06:53:34 PDT 2009
Yesterday, when I was playing with loading hundreds and
thousands big, small and very tiles and a mysterious bug
has revealed. I've made detailed tests which seem to confirm
there must be a bug in rt_core or rt_pg modules.
Below, I explain how to reproduce the problem:
0. 32-bit Linux (Ubuntu 8.10)
1. Simple table
CREATE TABLE car5
  rid serial NOT NULL,
  rast raster
2. Simple RGB raster: 5 x 5 with 3 bands,
each of pixel type of PT_8BUI (0x04) and NODATA = 0x00
3. Insert the same raster 3 times and check pixel types
of all bands after every insert
rtest=# INSERT INTO car5 ( rast ) VALUES ( ('01000003009A9999999999A93F9A9999999999A9BF000000E02B274A41000000F07619564100000000000000000000000000000000FFFFFFFF050005000400E5E7F5FAF3F9F9F8FBFDF3EEF5FBFEF9FCFBFBFEFCFBFCFAFB04004D4A4B505946444850514B4754524D52594F4A444E504D514D04003F363B41403536383A3F36333E413F4546403E3746453D3C3E')::raster );
INSERT 0 1
rtest=# select rid, rt_width(rast), rt_height(rast), rt_bandpixeltype(rast,1), rt_bandpixeltype(rast,2), rt_bandpixeltype(rast,3) from car5;
 rid | rt_width | rt_height | rt_bandpixeltype | rt_bandpixeltype | rt_bandpixeltype
  1 |        5 |         5 | 8BUI             | 1BB              | 1BB
(1 row)
INSERT 0 1
  2 |        5 |         5 | 8BUI             | 8BUI             | 8BUI
(2 rows)
INSERT 0 1
  3 |        5 |         5 | 8BUI             | 1BB              | 1BB
(3 rows)
rtest=#
4. The result is obviously and mysteriously wrong. Rasters with
rid 1 and 3 have invalid pixel types of 2nd and 3rd bands.
If I issue the inserts more times the pattern repeats.
5. Rasters WKB examination shows what's wrong with the data - bands
with incorrectly reported pixel types above are truncated.
However, the total length of raster data is correct.
The format of raster hex dump below is:
1st row - raster header
2nd - first band
3rd - second band
4th - third band
Hopefully mailmain nor my mail client won't mess up th formatting,
so places of bands truncation is well visible.
rtest=# select rid, rast from car5;
 rid | rast
1 |
   0400E5E7F5FAF3F9F9F8FBFDF3EEF5FBFEF9FCFBFBFEFCFBFCFAFB00000000
   04004D4A4B505946444850514B4754524D52594F4A444E00000000
2 |
3 |
(3 rows)
rtest=#
In order to simplify testing this problem, I have added dedicated test
case for test/regress [1] package:
# bug_test_car5.sql
# bug_test_car5_expected
[1] http://svn.osgeo.org/postgis//spike/wktraster/test/regress/
I've run this test case on both architectures, 32-bit and 64-bit,
on Linux. The bug leaks only on 32-bit. On 64-bit everything works well.
What's more funky, is that the problem is quite random and leaks
depending on size of tiles.
For instance, I cut GDAL's small_world.tif [2] to tiles of
20x20 pixels and 10x10 pixels.
The first set of tiles works well.
The second one does not even load into table:
INSERT 0 1
INSERT 0 1
psql:sw10.sql:804: ERROR:  Unknown pixeltype 12
ROLLBACK
This is also related to the problem I'm explaining, pixel type
is broken because of bands truncation.
The raster used in car5 test is just "lucky" so pixel type
is determined as Zero (1BB = code 0).
The bands of small_world are being truncated, so the
pixel type is randomly read as value 12 (likely
a part of raster data value, of a some pixel).
[2] http://download.osgeo.org/gdal/data/gtiff/
This issue needs more testing, so I'd appreciate if more people
could try to run WKT Raster regression tests and report here:
1. CPU (32 or 64 bit)
2. Operating System (32 or 64 bit)
3. Result of test.
How to run the test (Unix-like only):
$ Build PostGIS from SVN trunk
$ svn co http://svn.osgeo.org/postgis//spike/wktraster/ wktraster
$ cd wktraster
$ ./autogen.sh
$ ./configure --with-postgis-source=/path/to/postgis/trunk
$ make
$ make check
$ sudo make install
$ make post-install-check
Check the tests report if bug_test_car5 failed or not.
Best regards,
Mateusz Loskot
Senior Programmer, Cadcorp
http://www.cadcorp.com
