[postgis-devel] Port Issues Google => Trac
Paragon Corporation lr at pcorp.us
Wed Apr 1 16:32:48 PDT 2009
Paul,
Try again -- still malformed.  You have some CDAta tags you formed as
<!CDATA
Instead of
<![CDATA[
Though that’s easy enough for me to fix so not a biggie. I already fixed in
my copy.
Can you CDATA the attachment_urls too.
Which version of SQLite does OSGEO use.  It appears with the newer trac and
newer Python I can use SQLite 3.+ series, but if I were to use that it
wouldn't be downward compatible.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, April 01, 2009 7:09 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Port Issues Google => Trac
Thy will be done. Same place, now w/ CDATA.
On Wed, Apr 1, 2009 at 3:57 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Paul,
> If its not too much trouble Cdata tags would be a bit better.  Would
> save me the trouble of trying to well-form it so my XSLT can deal with it.
> Thanks,
> Regina
> Paul Ramsey
> Sent: Wednesday, April 01, 2009 5:54 PM
> Subject: [postgis-devel] Port Issues Google => Trac
> If anyone wants to take a try at porting issues to Trac, the Google
> data is here now:
> http://cleverelephant.dyndns.org/~pramsey/postgis-issues.xml
> Not well-formed XML, the stuff between description tags isn't escaped,
> be warned. If you want to use a real XML parser on it, let me know and
> I'll generate that stuff inside CDATA blocks.
> Howard says the way to do it is to get a blank trac instance running,
> then take that SqlLite database and start inserting into it. Then you
> can review your progress / success by using your trac instance to explore
the data.
> Paul
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
