[postgis-devel] Port Issues Google => Trac
Paul Ramsey pramsey at opengeo.org
Wed Apr 1 16:47:02 PDT 2009
Third time lucky, same place.
SQLite version 2.8.16
P
On Wed, Apr 1, 2009 at 4:32 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Paul,
> Try again -- still malformed.  You have some CDAta tags you formed as
> <!CDATA
> Instead of
> <![CDATA[
> Though that’s easy enough for me to fix so not a biggie. I already fixed in
> my copy.
> Can you CDATA the attachment_urls too.
> Which version of SQLite does OSGEO use.  It appears with the newer trac and
> newer Python I can use SQLite 3.+ series, but if I were to use that it
> wouldn't be downward compatible.
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Wednesday, April 01, 2009 7:09 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Port Issues Google => Trac
> Thy will be done. Same place, now w/ CDATA.
> On Wed, Apr 1, 2009 at 3:57 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> Paul,
>> If its not too much trouble Cdata tags would be a bit better.  Would
>> save me the trouble of trying to well-form it so my XSLT can deal with it.
>> Thanks,
>> Regina
>> Paul Ramsey
>> Sent: Wednesday, April 01, 2009 5:54 PM
>> Subject: [postgis-devel] Port Issues Google => Trac
>> If anyone wants to take a try at porting issues to Trac, the Google
>> data is here now:
>> http://cleverelephant.dyndns.org/~pramsey/postgis-issues.xml
>> Not well-formed XML, the stuff between description tags isn't escaped,
>> be warned. If you want to use a real XML parser on it, let me know and
>> I'll generate that stuff inside CDATA blocks.
>> Howard says the way to do it is to get a blank trac instance running,
>> then take that SqlLite database and start inserting into it. Then you
>> can review your progress / success by using your trac instance to explore
> the data.
>> Paul
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
