[postgis-devel] Issue 146 in postgis: 1.4 ST_Distance and ST_Dwithin doesn't handle collections correctly
codesite-noreply at google.com codesite-noreply at google.com
Sat Apr 4 16:24:04 PDT 2009
Updates:
	Summary: 1.4 ST_Distance and ST_Dwithin doesn't handle collections
correctly
Comment #1 on issue 146 by robe.... at cityofboston.gov: 1.4 ST_Distance and
http://code.google.com/p/postgis/issues/detail?id=146
On closer inspection I'm guessing this is a bug we introduced when we tried
to
resolve the crashing bug for curved support in distance and that other
cleanup thing
I can't remember.
The problem seems to consistently happen in 1.4 if you have a collection
that
contains another geometry collection or a multi type geometry.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
