[postgis-devel] Issue 146 in postgis: 1.4 ST_Distance and ST_Dwithin doesn't handle collections correctly
codesite-noreply at google.com codesite-noreply at google.com
Sun Apr 5 05:10:53 PDT 2009
Comment #3 on issue 146 by post... at jordogskog.no: 1.4 ST_Distance and
http://code.google.com/p/postgis/issues/detail?id=146
Hallo
I found a bug in measures.c
It could handle collections and mult as the first incomming geometry but
not the
second. I think this patch solves it :-)
/Nicklas Avén
	st_distance_bugfix.patch  649 bytes
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
