[postgis-devel] Issue 145 in postgis: POLYGON( EMPTY) is unparseable
codesite-noreply at google.com codesite-noreply at google.com
Tue Apr 7 04:43:24 PDT 2009
Updates:
	Status: Accepted
Comment #3 on issue 145 by robe.... at cityofboston.gov: POLYGON( EMPTY) is
unparseable
http://code.google.com/p/postgis/issues/detail?id=145
Actually using the ST_Area was how we discovered the issue too when it
broke our code
using ST_Area with that getPoint2d_p.  And on inspection it seemed that
Buffer was
just returning a POLYGON( EMPTY) which would otherwise be fine except we
don't seem
to know how to parse POLYGON(EMPTY).  Shouldn't POLYGON(EMPTY) be a valid
construct?
  Though as Leo said its POLYGON(spaceEMPTY) its returning or at least that
is how
PostGIS interprets it.
Now for Paul's example -- testing on my Windows 8.3 1.4/3.1.0 install it
doesn't
crash   -- I get this
ERROR:  geometry contains non-closed rings
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
