[postgis-devel] Issue 147 in postgis: regress_ogc_prep fails with PostgreSQL crash
codesite-noreply at google.com codesite-noreply at google.com
Wed Apr 8 02:36:46 PDT 2009
Status: New
Owner: ----
New issue 147 by mloskot: regress_ogc_prep fails with PostgreSQL crash
http://code.google.com/p/postgis/issues/detail?id=147
What steps will reproduce the problem?
1. Update/Checkout Revision 3986 of SVN trunk
2. Configure
./autogen.sh && ./configure
3. (Re)Build
make clean && make && sudo make install && make check
4. Check tests result
  regress_ogc_cover. ok
  regress_ogc_prep. failed (diff expected obtained:
/tmp/pgis_reg_32763/test_42_diff)
Run tests: 42
Failed: 1
5. There are many diff lines in file /tmp/pgis_reg_32763/test_42_diff
and at the end there is message indicating that PostgreSQL crashed:
! server closed the connection unexpectedly
! 	This probably means the server terminated abnormally
! 	before or while processing the request.
! connection to server was lost
Operating system information:
Tests run under Linux (Ubuntu 8.10) on 32-bit and 64-bit machines.
Two files attached with test_42_diff output:
32bit-trunk-r3986- regress_ogc_prep-fail-diff.txt
64bit-trunk-r3986- regress_ogc_prep-fail-diff.txt
	32bit-trunk-r3986- regress_ogc_prep-fail-diff.txt  2.0 KB
	64bit-trunk-r3986- regress_ogc_prep-fail-diff.txt  2.0 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
