[postgis-devel] Issue 143 in postgis: regress_ogc failed for trunk on Linux
codesite-noreply at google.com codesite-noreply at google.com
Wed Apr 8 03:19:14 PDT 2009
Comment #2 on issue 143 by mloskot: regress_ogc failed for trunk on Linux
http://code.google.com/p/postgis/issues/detail?id=143
FYI, I've re-run the tests using today updates of PostGIS and GEOS:
mloskot at vb-ubuntu810-i386:~/dev/geos/_svn/trunk$ svn info | grep Revision
Revision: 2321
mloskot at vb-ubuntu810-i386:~/dev/postgis/_svn/trunk$ svn info | grep Revision
Revision: 3986
The test still fails and server terminates connection and gets lost.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
