[postgis-devel] Compilation using Visual C++ 8.0
Mateusz Loskot mateusz at loskot.net
Wed Apr 8 05:06:24 PDT 2009
Mark Cave-Ayland wrote:
> Mateusz Loskot wrote:
>>> - I don't see any evidence of building liblwgeom into a static
>>> library. This is needed because not only does the library link
>>> with postgis-1.4.dll, but also with the shapefile loaders. I
>>> think this is also a critical part of the build to get right.
>> See liblwgeom.vcproj which produces liblwgeom.lib
> Okay, now I see - sorry I must have skimmed this when I read the
> patch. So I can see that liblwgeom is now built from source, but I
> still can't see invocation of the parser utilities such as flex/bison
>  to generate lex.yy.c/wktparse.tab.c from source.
These files are available in the trunk, so I've not added extra steps.
However, it should be possible to define pre-build step and use
bison/flex from GnuWin32 package.
>>> Also I'd like to see evidence of a clean regression run from an
>>> MSVC build before committing some of this into the repository -
>>> just because it builds doesn't necessarily mean that it works ;)
>> You are right. I've run some of tests I selected randomly, i.e.
>> regress.sql but I have not run full regress package.
>> Just to make things clear, I've prepared the build using Visual C++
>>  as a proof of concept, to show that there is no rocket science
>> necessary to make it working, without using MinGW. However, I'm not
>>  going to pursue to submit it to the official PostGIS tree. I'm
>> also not going to become maintainer of this configuration. I'm only
>>  going to update it if I have a free gap in my time or if I need it
>>  working myself.
> Then unfortunately I think this project is probably dead :(
Yes, I'm aware of that :-)
> Since the new build system has been overhauled,
What's the new build system?
> I've pointed out several times that an MSVC build should now be
> relatively easy to do, it just needs someone to support it because
> the MS build tools live in their own little universe away from
> everyone else. I think that the work you've done here is great, but
> it comes back to the core issue that no one is willing to step up and
>  maintain the MSVC build.
Understood.
If time allows, I will post updates on my website. So, if anyone will
be interested in testing/using it, then it's there.
> From a personal perspective, I'm happy with MingW because the
> existing build system just works whether it's on Windows or Linux. I
> can get backtraces if required with gdb, and if I want a debug GUI
> then I can always stretch to Eclipse/CDT.
OK
> There is just no way we can justify forcing developers to maintain
> parts of the MSVC builds which most of them can't even test just for
> the sake of one platform.
Agreed.
Anyways, that was an interesting experience to me and perhaps
somebody will find the results useful too.
Mark, thanks for your time!
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
