[postgis-devel] Issue 148 in postgis: st_touches doesn't work as it should on st_touches(line,point)
codesite-noreply at google.com codesite-noreply at google.com
Wed Apr 8 09:02:03 PDT 2009
Comment #3 on issue 148 by ke... at refractions.net: st_touches doesn't work
http://code.google.com/p/postgis/issues/detail?id=148
umm.. correction.
that should've read
2. the intersection of the interior of (a) and the interior of (b) IS the
empty set.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
