[postgis-devel] Status of shp2pgsql-core/shp2pgsql?
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Sun Apr 12 12:49:07 PDT 2009
Paragon Corporation wrote:
> While you guys are at it can you refix what you had fixed that got broken by
> Mark's change unless we are okay with popel getting these warnings sometime.
> More importantly I think something else got broken by Marks change but not
> sure if its just the test shape file I was using, but it worked before Mark
> made his change.  I attached it to the ticket.
Yes, I believe I fixed it this morning. See the update on ticket #123.
> On another note -- do we have trac bug reports going to the postgis-dev
> mailing list.  I don't seem to be seeing them coming thru on the list though
> I do get them personally when I post them.
Yeah, I'm sure what the current configuration is, although I seem to be
getting emails through from trac when I update a ticket.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
