[postgis-devel] Probe_Geometry_Columns() only in public schema?
Per-Olof Norén pelle at alma.nu
Wed Apr 22 07:34:12 PDT 2009
Thanks Kevin,
It looks very promising.
I'll give it a try
/P-O
Kevin Neufeld skrev:
> You could try to import the new Populate_Geometry_Columns() that's
> available in 1.4 into your 1.3.3 database.  One variant of this method
> takes a table oid which you could use to iterate over all tables in a
> particular schema.
> http://postgis.refractions.net/documentation/manual-svn/Populate_Geometry_Columns.html
> The difference between Probe_Geo.. and Populate_Geo... is that probe
> requires that your geometry columns were originally added to your
> tables via AddGeometryColumns() (or the table constraints were added
> manually), populate does not.
> -- Kevin
> Per-Olof Norén wrote:
>> Hi guys,
>> I have a database where all tables with geometry data is in (8)
>> different schemas.
>> Having destroyed the data in my geometry_columns table, I looked
>> around for managment function and found Probe_Geometry_Columns().
>> After running probe_geometry_columns it reports having scanned only
>> my two tables in the public schema (geometry_columns + spatial_ref_sys)
>> Is this a known limitation on 1.3.3 ?
>> (select postgis_lib_version() => 1.3.3)
>> A suggestion might be to supply a schema name as argument?
>> Regards,
>> Per-Olof
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
