[postgis-devel] Can we do a final 1.3.6RC2 and go live
Paragon Corporation lr at pcorp.us
Wed Apr 29 21:57:05 PDT 2009
Kevin,
I guess the only thing that did fail that I thought we had fixed and then
realized we only did it for 1.4 is this one
http://trac.osgeo.org/postgis/ticket/104
But it works, just gives warnings and larger shape files I loaded and dumped
seem to work fine too.  I guess since the problem has always been there its
probably not worth fixing for 1.3 series and risk breaking it in unless if
someone feels its worthwhile.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Kevin
Neufeld
Sent: Thursday, April 30, 2009 12:18 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Can we do a final 1.3.6RC2 and go live
Yes, I'm testing the branch and trunk against 8.2.13, 8.3.7, and 8.4beta.
http://office.refractions.net:1500/view/PostGIS%20Branch/
1.3.6 passes without a hitch on 8.4.
http://office.refractions.net:1500/view/PostGIS%20Branch/job/PostGIS-branch-
regress84/ws/regress_results/results.log/*view*/
-- Kevin
Paragon Corporation wrote:
> I finally got around to testing 1.3.6RC1 and 1.3.6SVN on my OpenSUSE
> 11 running  PostgreSQL 8.4beta1 on i686-pc-linux-gnu, compiled by GCC
> gcc (GCC) 3.4.6
> 20060404 (Red Hat 3.4.6-10), 32-bit
>  Postgis 1.3.6SVN - 2009-04-30 03:38:51
>    GEOS: 3.1.0-CAPI-1.5.0
>    PROJ: Rel. 4.6.0, 21 Dec 2007
> I'm content everything works as expected.
> Make check passes except for kml which didn't pass in 1.3.5 anyway.
> Kevin -- did you ever test 1.3.6 on 8.4 beta or you just tested the
> 1.4 branch?
>  I would have assumed I would get similar false positive errors you
> got in
> 1.4 make check in my 1.3.6 tests, but I didn't.  I have yet to do a
> make check on 1.4 against 8.4.
> Anyrate -- can we have 1 more RC just so people can test those last
> minute changes we put in and go live next week if no one complains?
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
