[postgis-devel] WKTRaster autobuilds
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Thu Apr 30 05:43:40 PDT 2009
Thanks a lot Kevin. Appreciate.
Pierre
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Kevin Neufeld
>Sent: 29 avril 2009 18:19
>To: PostGIS Development Discussion
>Subject: Re: [postgis-devel] WKTRaster autobuilds
>I'm not sure how Mateusz is going with OsGeo's buildbot farm, but in
the mean time, I've set up our
>own here at
>Refractions to test building snapshots, perform regregression testing
and so forth.  I think it's
>useful to perform test
>builds on as many machines as possible - hopefully diverse in their
configuration.
>I set one up for WKT here that will autobuild after every commit to
spike/wktraster
>http://office.refractions.net:1500/view/WKTRaster
>I'm currently posting a tarball to the PostGIS/downloads website.
>http://postgis.refractions.net/download/wktraster-0.0.0.tar.gz
>Do you want me to do this or did you want the buildbot on OsGeo to take
care of this?
>(As in the other snapshot builds, I'm using the version info from
Version.config)
>The question I have is, the "make check" target spits out a lot of
WARNINGS and several ERRORs - is
>this to be expected
>with the current svn snapshot, or is my configuration amiss?
>http://office.refractions.net:1500/view/WKTRaster/job/WKTRaster-trunk-c
heck/ws/check.log/*view*/
>Cheers,
>Kevin
>Kevin Neufeld wrote:
>> Hi Pierre,
>> Ever since the autogen changes to PostGIS (2 weeks ago?), our
autobuild
>> box has been out of commission in terms of building anything at all
>> (PostGIS tarball, docs, etc. are all suspended).  At that time, we
tried
>> to update libtoolize among other things to get the build working
again,
>> but to no avail ... now nothing builds.
>> I started setting up an autobuild for WKTRaster but have been unable
to
>> get the code to compile at all ... probably due to the now messed up
>> build environment.  I've been insanely busy here with other projects
I
>> hadn't had a chance to look into this further (they say later this
month
>> things should slow down a bit for us ... so I may have time to look
into
>> this soon.)
>> In the mean time, I'm looking forward to what Mateusz sets up using
>> OsGeo's buildbot farm.  Perhaps WKTRaster can hook into that as well.
>> Cheers,
>> Kevin
>> Pierre Racine wrote:
>>> Kevin,
>>> Will we get at least the tarball?
>>> Pierre
>>>> Sent: 9 mars 2009 18:07
>>>> Subject: [postgis-devel] WKTRaster autobuilds
>>>> Hi all,
>>>> It's been suggested that I add the WKTRaster project as another job
to
>>> the autobuild system we
>>>> currently employ for PostGIS.
>>>> For those that don't know, PostGIS currently uses Hudson
>>> (http://postgis.refractions.net:8082/) to
>>>> automatically perform
>>>> nightly builds (JDBC and other change logs) and immediate builds
>>> (hooked into SVN of the 1.3 and trunk
>>>> branches that
>>>> builds 5 minutes after every commit).  It also builds all the
>>> documentation for the main
>>>> website.
>>>> Is this something the WKTRaster project would like as well?  Would
this
>>> be helpful and is the code
>>>> stable enough?
>>>> (Hudson would spam the last person who broke the build ... which
could
>>> be rather annoying when the
>>>> code is still very
>>>> new and under heavy development.)
>>>> What about adding a tarball of the project to the PostGIS downloads
>>> section on the main website?
>>>> Just some thoughts ...
>>>> -- Kevin
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
