[postgis-devel] [PostGIS] #230: st_expand seems to affect the execution order wich affects st_dwithin
PostGIS trac at osgeo.org
Tue Aug 4 07:08:38 PDT 2009
 Reporter:  nicklas                    |       Owner:  pramsey
     Type:  defect                     |      Status:  new
 Priority:  medium                     |   Milestone:  postgis 1.5.0
Component:  postgis                    |     Version:
 Keywords:  st_dwithin st_expand bbox  |
 using dataset from states.backup as example
 the bbox-comparasion doesn't seem to always happen before the _st_dwithin
 calculations.
 To isolate the problem I used _st_dwithin instead of st_dwithin and played
 with the bbox-comparasions in the query instead.
 then,
 if I run:
 select a.state from us.states a, us.states b
         where b.state = 'Hawaii' and a.state != 'Hawaii'
                 and a.the_geom && b.the_geom;
 or
                 and st_expand(a.the_geom, 0) && b.the_geom;
 it tells in 30 ms that there is no hit, just as expected
 the same happens if I try:
                 and a.the_geom && b.the_geom and _st_dwithin(a.the_geom,
 b.the_geom, 0);
 fast answer that there is no hit.
 BUT
 if I run
                 and st_expand(a.the_geom, 0) && b.the_geom and
 _st_dwithin(a.the_geom, b.the_geom, 0);
 then, the fun is over. It starts running for 220000 ms before I get the
 answer.
 My guess is that in this case _st_dwithin is trigged before the bbox-
 comparation so it makes the distance calculations to every one of the
 other polygons in the dataset.
 It behaves the same if I run:
                 and st_dwithin(a.the_geom, b.the_geom,0)
 where the function is supposed to handle the bbox-comparasion.
 /Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/230>
