[postgis-devel] [PostGIS] #230: Put in costs in _ST and possibly other functions
PostGIS trac at osgeo.org
Sat Aug 8 23:27:37 PDT 2009
  Reporter:  nicklas  |       Owner:  robe
      Type:  defect   |      Status:  assigned
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:  1.4
Resolution:           |    Keywords:  st_dwithin st_expand bbox
Changes (by robe):
  * summary:  st_expand seems to affect the execution order wich affects
              st_dwithin => Put in costs in _ST and possibly
              other functions
  * milestone:  postgis 1.4.1 => postgis 1.5.0
Old description:
> using dataset from states.backup as example
> the bbox-comparasion doesn't seem to always happen before the _st_dwithin
> calculations.
> To isolate the problem I used _st_dwithin instead of st_dwithin and
> played with the bbox-comparasions in the query instead.
> then,
> if I run:
> select a.state from us.states a, us.states b
>         where b.state = 'Hawaii' and a.state != 'Hawaii'
>                 and a.the_geom && b.the_geom;
> or
>                 and st_expand(a.the_geom, 0) && b.the_geom;
> it tells in 30 ms that there is no hit, just as expected
> the same happens if I try:
>                 and a.the_geom && b.the_geom and _st_dwithin(a.the_geom,
> b.the_geom, 0);
> fast answer that there is no hit.
> BUT
> if I run
>                 and st_expand(a.the_geom, 0) && b.the_geom and
> _st_dwithin(a.the_geom, b.the_geom, 0);
> then, the fun is over. It starts running for 220000 ms before I get the
> answer.
> My guess is that in this case _st_dwithin is trigged before the bbox-
> comparation so it makes the distance calculations to every one of the
> other polygons in the dataset.
> It behaves the same if I run:
>                 and st_dwithin(a.the_geom, b.the_geom,0)
> where the function is supposed to handle the bbox-comparasion.
> /Nicklas
New description:
 I'm revising this since this seems to be an issue mostly because we don't
 have COSTS assigned to our _ST functions, so the planner in certain cases
 (like with large geometries), chooses to do a table scan instead of an
 index scan.
 Since costs are only supported in PostgreSQL 8.3+ and we are also going to
 need typmod support for geography.  I'm wondering if we want to just push
 this to 1.5 and also make PostgreSQL 8.3+ a requirement for 1.5 instead of
 introducing messy conditional code to not put costs in if 8.2 or lower.
 ----OLD description
 calculations.
 To isolate the problem I used _st_dwithin instead of st_dwithin and played
 then,
 if I run:
 or
 b.the_geom, 0);
 BUT
 if I run
 answer.
 /Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/230#comment:14>
