[postgis-devel] [PostGIS] #237: loader makefile CFLAGS altered by PGXS
PostGIS trac at osgeo.org
Sun Aug 9 07:51:03 PDT 2009
  Reporter:  kyngchaos  |       Owner:  robe
      Type:  defect     |      Status:  assigned
  Priority:  medium     |   Milestone:  postgis 1.4.1
 Component:  postgis    |     Version:  1.4.X
Resolution:             |    Keywords:
Comment (by kyngchaos):
 I didn't try to compile shp2pgsql-gui, I don't want the hassle of
 compiling GTK on OSX.  But since it has a rule in the makefile, it would
 have the same problem.
 It's not really a problem of not compiling at all - if I left it to build
 a single architecture (native) it would work.  Even with the arch flags it
 links, just a single native architecture.
 If you are adding any linking flags to CFLAGS for Windows compilation,
 then it's probably affecting you.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/237#comment:2>
