[postgis-devel] [PostGIS] #231: New distance-calculations proposal
PostGIS trac at osgeo.org
Mon Aug 10 01:03:34 PDT 2009
  Reporter:  nicklas      |       Owner:  robe
      Type:  enhancement  |      Status:  assigned
  Priority:  medium       |   Milestone:  postgis 1.5.0
 Component:  postgis      |     Version:
Resolution:               |    Keywords:
Comment (by robe):
 Nicklas,
 I took a quick look at your code.  Your commenting style for function
 description is a little off so I don't think it will be picked up by our
 doxygen auto documentor.  YOu probably made the mistake of copying some of
 the bad commenting style in the other parts of the code base. Please read
 below (which is still a work in progress).
 http://trac.osgeo.org/postgis/wiki/DevWikiPatch
 Paul if you are not asleep, can you fill in the section on CUnit Testing
 http://trac.osgeo.org/postgis/wiki/DevWikiMain
Ticket URL: <http://trac.osgeo.org/postgis/ticket/231#comment:11>
