[postgis-devel] PostGIS build error on F-11
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Aug 10 02:08:52 PDT 2009
Devrim GÜNDÜZ wrote:
> On Thu, 2009-07-30 at 23:55 +0100, Mark Cave-Ayland wrote:
>> http://koji.fedoraproject.org/koji/getfile?taskID=1566679&name=build.log
>> That's really weird, as the various functions are defined without any
>> problems here. Could it be a problem with parallel make? What happens
>> if
>> you remove the -j4 during the build?
Looks like the above web link doesn't work anymore :(
> I think I cannot remove it -- this is an automated process.
It looks like the -j flags are set for the %make macro - as a test, can
you not just replace %make with make in the spec file?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
