[postgis-devel] trunk regress fails - PostgreSQL Minimum version?
Paragon Corporation lr at pcorp.us
Tue Aug 11 14:34:01 PDT 2009
The buffer functions work fine for me on 8.4.  Kevin, was this just in 8.2?
If I have my way -- we won't be supporting 8.2 for PostGIS 1.5 so would be a
moot point.
Or shall I say one more reason to ditch 8.2 :)
Paul and Kevin -- I think Mark and I are in agreement on ditching 8.2 for
1.5 what about you 2?
I know Kevin gave a +1 to the matrix -- and I'm in full agreement we need a
matrix (listing at the very minimum for each PostGIS version which
PostgreSQL versions we support).  I'd be willing to write that up too.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of strk
Sent: Tuesday, August 11, 2009 12:19 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] trunk regress fails
On Wed, Aug 05, 2009 at 10:01:31AM +0100, Mark Cave-Ayland wrote:
> Kevin Neufeld wrote:
> >ERROR:  cannot cast type text to cstring
> >LINE 4:   CAST('quad_segs='||CAST($3 AS text) as cstring))
> Hmmmm looks like this was introduced by strk's new buffer code. If we
> ask him nicely, will he fix it? ;)
I remember a similar problem with 8.3, which forced me to cast as 'text'
first and 'cstring' second (direct casting wasn't supported).
I'm afraid it'll take some pg-version-specific macro to fix this.
I can only test 8.3.7 atm, if anyone provides a fix for older I will try
there.
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
