[postgis-devel] trunk regress fails - PostgreSQL Minimum version?
strk strk at keybit.net
Wed Aug 12 00:17:45 PDT 2009
On Tue, Aug 11, 2009 at 03:44:27PM -0700, Kevin Neufeld wrote:
> If I change the 'sed' line 88
> (http://trac.osgeo.org/postgis/browser/trunk/regress/Makefile.in#L88) with
> a simple 'cp ../postgis/postgis.sql postgis.sql', all is well.
> So, strk's commit at r4284 (http://trac.osgeo.org/postgis/changeset/4284)
> broke it for me.
'sed' is also used in postgis/Makefile, does it work there for you ?
We do need to edit the sql file in order to have it use the pre-installed
library...
> # Regression Test
> cd regress
> make
Just an hint: you should be able to run 'make check' from top-level dir.
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
