[postgis-devel] [PostGIS] #222: GUI compile under MinGW
trac at osgeo.org
Thu Aug 13 01:34:26 PDT 2009
Reporter: pramsey | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.4.1
Component: postgis | Version: 1.4.X
Resolution: | Keywords:
Comment (by alexbruy):
I also can't build GUI with MinGW and MSYS. I do all as described in pages
http://trac.osgeo.org/postgis/wiki/UsersWikiWinCompileWithgui and
http://trac.osgeo.org/postgis/wiki/UsersWikiWinCompile but when linking to
shp2pgsql-gui.exe there are lots of errors (full log attached -
build_log.zip).
I try to recompile libiconv from sources ( version 1.13.1 from
http://ftp.gnu.org/gnu/libiconv/) but with no result. Also I try to use
gettext from MSYS (both bin- and dev- packages) and no result again -
errors while linking.
Tested with PostGIS 1.4.0 (SVN 4365) and PostGIS 1.4.1 (SVN 4393), MinGW
5.1.4, MSYS 1.0.11, Windows XP Pro SP3
Ticket URL: <http://trac.osgeo.org/postgis/ticket/222#comment:15>
