[postgis-devel] Strange result about spatial indexes?
Paul Ramsey pramsey at opengeo.org
Fri Aug 14 12:20:19 PDT 2009
It's (no surprise) about the data interacting with the PgSQL caching
behavior (which I'd love Tom to pipe up about) The data include some
very large polygons, that have a lot of overlap with other polygons.
So they cause a lot of runs through the consistent check, which don't
seem to happen in the immutable function case.
suelos=# select p1.gid, sum(npoints(p1.geom))/count(*) as npoints,
count(*) from suelos1 p1, suelos1 p2 where p1.geom && p2.geom group by
p1.gid order by count desc;
 gid  | npoints | count
 265 |    4889 |   236
 136 |    2292 |   216
 645 |    1215 |   132
 315 |     842 |   116
 237 |    1742 |   115
  75 |    1339 |    97
 589 |    1331 |    92
 134 |     713 |    79
 274 |    1316 |    73
 807 |    1397 |    66
 511 |     714 |    62
 534 |     492 |    55
 999 |    3693 |    55
 1028 |     850 |    54
 1067 |    1195 |    52
 162 |     329 |    52
 764 |     286 |    50
 720 |     574 |    48
 904 |     316 |    48
 1313 |    1616 |    46
  22 |     336 |    43
The amount re-calculation this kind of overlap forces can also be seen
in the performance difference between the (preparedgeometry)
st_intersects() and the (oldskool) st_dwithin() tests:
suelos=# select count(*) from suelos1 p1, suelos1 p2 where
st_dwithin(p1.geom, p2.geom, 0.0);
 count
 8566
(1 row)
Time: 103100.780 ms
st_intersects(p1.geom, p2.geom);
 count
 8566
(1 row)
Time: 6136.734 ms
Anyhow, the question remains, at a PgSQL level, why adding that
immutable function causes so many fewer calls into GiST consistent
(which makes so much difference).
On Fri, Aug 14, 2009 at 10:34 AM, Paul Ramsey<pramsey at opengeo.org> wrote:
> No surprise, any function that returns cheaply and immutably will
> provide the same effect. The effect is so huge, that you can even get
> faster results using expensive functions.
> (st_envelope(p1.geom) && p2.geom);
>  count
>  13808
> (1 row)
> Time: 92.989 ms
> (st_setsrid(p1.geom,23030) && p2.geom);
>  count
>  13808
> (1 row)
> Time: 92.626 ms
> (st_convexhull(p1.geom) && p2.geom); count
>  13808
> (1 row)
> Time: 237.928 ms
> suelos=# select count(*) from suelos1 p1, suelos1 p2 where (p1.geom && p2.geom);
>  count
>  13808
> (1 row)
> Time: 478.765 ms
