[postgis-devel] Strange result about spatial indexes?
Paul Ramsey pramsey at cleverelephant.ca
Fri Aug 14 20:54:57 PDT 2009
Hi everyone,
I have one table, with around 25000 polygons.
Why the predicate (st_expand(p1.geom,0) && p2.geom) takes 6.5seg and the
predicate p1.geom && p2.geom takes 203seg? I though the predicate
(st_expand(p1.geom,0) && p2.geom) should be a little bit slower than
p1.geom && p2.geom though.
Thanx to all,
cheers,
Jose carlos
test3=# explain analyze select count(*) from suelos1 p1, suelos1 p2
where (st_expand(p1.geom,0) && p2.geom);
        QUERY
PLAN
 Aggregate  (cost=19540.00..19540.01 rows=1 width=0) (actual
time=6554.345..6554.347 rows=1 loops=1)
  ->  Nested Loop  (cost=0.00..19531.88 rows=3248 width=0) (actual
time=0.178..6158.890 rows=251009 loops=1)
        ->  Seq Scan on suelos1 p1  (cost=0.00..2491.87 rows=25487
width=5617) (actual time=0.012..48.288 rows=25487 loops=1)
        ->  Index Scan using suelos_geom_idx on suelos1 p2
(cost=0.00..0.65 rows=1 width=5617) (actual time=0.107..0.197 rows=10
loops=25487)
              Index Cond: (st_expand(p1.geom, 0::double precision) &&
p2.geom)
 Total runtime: 6554.427 ms
(6 rows)
where (p1.geom && p2.geom);
        QUERY
PLAN
 Aggregate  (cost=19659.32..19659.33 rows=1 width=0) (actual
time=203766.354..203766.356 rows=1 loops=1)
  ->  Nested Loop  (cost=0.00..19404.44 rows=101948 width=0) (actual
time=0.158..203312.648 rows=251009 loops=1)
width=5617) (actual time=0.010..60.117 rows=25487 loops=1)
(cost=0.00..0.65 rows=1 width=5617) (actual time=3.288..7.936 rows=10
loops=25487)
              Index Cond: (p1.geom && p2.geom)
 Total runtime: 203766.439 ms
(6 rows)
test3=# select postgis_full_version();
 POSTGIS="1.4.0" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.1, 21 August
2008" USE_STATS
(1 row)
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
