[postgis-devel] Strange result about spatial indexes?
Paul Ramsey pramsey at cleverelephant.ca
Fri Aug 14 22:14:28 PDT 2009
Tom,
That patch seems to make a salutary difference, at least against this
workload... there is now no difference between the
query-with-immutable-function and the bare query.
pramsey=# explain analyze select count(*) from suelos1 s1, suelos1 s2
where (s1.geom && s2.geom);
        QUERY
PLAN
 Aggregate  (cost=1075.91..1075.92 rows=1 width=0) (actual
time=118.821..118.822 rows=
1 loops=1)
   ->  Nested Loop  (cost=0.00..1059.87 rows=6416 width=0) (actual
time=0.062..116.433
 rows=13808 loops=1)
         ->  Seq Scan on suelos1 s1  (cost=0.00..126.04 rows=1604
width=4597) (actual
time=0.007..0.581 rows=1604 loops=1)
         ->  Index Scan using suelos1_gix on suelos1 s2
(cost=0.00..0.57 rows=1 width
=4597) (actual time=0.038..0.063 rows=9 loops=1604)
               Index Cond: (s1.geom && s2.geom)
 Total runtime: 118.918 ms
(6 rows)
where (st_expand(s1.geom,00) && s2.geom);
        QUERY
PLAN
 Aggregate  (cost=1067.92..1067.93 rows=1 width=0) (actual
time=125.488..125.488 rows=
1 loops=1)
   ->  Nested Loop  (cost=0.00..1067.89 rows=13 width=0) (actual
time=0.056..122.873 r
ows=13808 loops=1)
width=4597) (actual
time=0.008..0.706 rows=1604 loops=1)
=4597) (actual time=0.039..0.065 rows=9 loops=1604)
               Index Cond: (st_expand(s1.geom, 0::double precision) && s2.geom)
 Total runtime: 125.594 ms
(6 rows)
pramsey=#
On Fri, Aug 14, 2009 at 9:38 PM, Tom Lane<tgl at sss.pgh.pa.us> wrote:
> Paul Ramsey <pramsey at cleverelephant.ca> writes:
>> Frankly, now that we know this trick, since most of our index calls
>> are now hidden inside SQL facades (eg ST_Intersects()), we can further
>> wrap the index operations in no-op immutable functions to force this
>> behavior. And add an ST_MBRIntersects() function which does nothing
>> more than toss in a wrapper function. It's a hack, but c'est la vie.
>> Most of the time the effect won't be 10:1 like this example data set
>> showed -- this data just happens to have some high degrees of overlap,
>> so the inefficiency gets lots of exercise.
> This is definitely the exact same issue that Mark Cave-Ayland complained
> about last year:
> http://archives.postgresql.org/pgsql-hackers/2008-06/msg00384.php
> The proposal I had to fix it
> http://archives.postgresql.org/pgsql-hackers/2008-06/msg00709.php
> more or less crashed and burned, because it was too complicated and
> didn't buy enough in return.  But I wonder if we couldn't fix your
> problem with a less ambitious, less invasive approach, like the
> attached.  Which is actually a three-statement patch, but it looks
> bigger because I had to rearrange the existing code a trifle.
> This is against CVS HEAD, but applies cleanly to 8.4, and could be
> applied to 8.3 with only minor work.
>                        regards, tom lane
> Index: src/backend/executor/nodeIndexscan.c
> RCS file: /cvsroot/pgsql/src/backend/executor/nodeIndexscan.c,v
> retrieving revision 1.133
> diff -c -r1.133 nodeIndexscan.c
> *** src/backend/executor/nodeIndexscan.c        18 Jul 2009 19:15:41 -0000      1.133
> --- src/backend/executor/nodeIndexscan.c        15 Aug 2009 04:28:55 -0000
> *** 237,244 ****
> --- 237,247 ----
>  ExecIndexEvalRuntimeKeys(ExprContext *econtext,
>                                                 IndexRuntimeKeyInfo *runtimeKeys, int numRuntimeKeys)
> +       MemoryContext oldContext;
>        int                     j;
> +       oldContext = MemoryContextSwitchTo(econtext->ecxt_per_tuple_memory);
>        for (j = 0; j < numRuntimeKeys; j++)
>                ScanKey         scan_key = runtimeKeys[j].scan_key;
> *** 256,273 ****
>                 * econtext->ecxt_per_tuple_memory.  We assume that the outer tuple
>                 * will stay put throughout our scan.  If this is wrong, we could copy
>                 * the result into our context explicitly, but I think that's not
> !                * necessary...
> !               scanvalue = ExecEvalExprSwitchContext(key_expr,
> !        econtext,
> !        &isNull,
> !        NULL);
> !               scan_key->sk_argument = scanvalue;
>                if (isNull)
>                        scan_key->sk_flags |= SK_ISNULL;
>                else
>                        scan_key->sk_flags &= ~SK_ISNULL;
> --- 259,290 ----
> !                * necessary.
> !                * It's also entirely possible that the result of the eval is a
> !                * toasted value.  In this case we should forcibly detoast it,
> !                * to avoid repeat detoastings each time the value is examined
> !                * by an index support function.
> !               scanvalue = ExecEvalExpr(key_expr,
> !        econtext,
> !        &isNull,
> !        NULL);
>                if (isNull)
> +                       scan_key->sk_argument = scanvalue;
>                else
> +                       if (runtimeKeys[j].key_toastable)
> +                               scanvalue = PointerGetDatum(PG_DETOAST_DATUM(scanvalue));
> +       MemoryContextSwitchTo(oldContext);
> *** 795,800 ****
> --- 812,819 ----
>                                runtime_keys[n_runtime_keys].scan_key = this_scan_key;
>                                runtime_keys[n_runtime_keys].key_expr =
>                                        ExecInitExpr(rightop, planstate);
> +                               runtime_keys[n_runtime_keys].key_toastable =
> +                                       TypeIsToastable(op_righttype);
>                                n_runtime_keys++;
>                                scanvalue = (Datum) 0;
> *** 844,849 ****
> --- 863,893 ----
>                                varattno = ((Var *) leftop)->varattno;
> +                                * We have to look up the operator's associated btree support
> +                                * function
> +                               opno = lfirst_oid(opnos_cell);
> +                               opnos_cell = lnext(opnos_cell);
> +                               if (index->rd_rel->relam != BTREE_AM_OID ||
> +                                       varattno < 1 || varattno > index->rd_index->indnatts)
> +                                       elog(ERROR, "bogus RowCompare index qualification");
> +                               opfamily = index->rd_opfamily[varattno - 1];
> +                               get_op_opfamily_properties(opno, opfamily,
> +        &op_strategy,
> +        &op_lefttype,
> +        &op_righttype);
> +                               if (op_strategy != rc->rctype)
> +                                       elog(ERROR, "RowCompare index qualification contains wrong operator");
> +                               opfuncid = get_opfamily_proc(opfamily,
> +        op_lefttype,
> +        op_righttype,
> +        BTORDER_PROC);
>                                 * rightop is the constant or variable comparison value
>                                rightop = (Expr *) lfirst(rargs_cell);
> *** 867,902 ****
>                                        runtime_keys[n_runtime_keys].scan_key = this_sub_key;
>                                        n_runtime_keys++;
> -                                * We have to look up the operator's associated btree support
> -                                * function
> -                               opno = lfirst_oid(opnos_cell);
> -                               opnos_cell = lnext(opnos_cell);
> -                               if (index->rd_rel->relam != BTREE_AM_OID ||
> -                                       varattno < 1 || varattno > index->rd_index->indnatts)
> -                                       elog(ERROR, "bogus RowCompare index qualification");
> -                               opfamily = index->rd_opfamily[varattno - 1];
> -                               get_op_opfamily_properties(opno, opfamily,
> -        &op_strategy,
> -        &op_lefttype,
> -        &op_righttype);
> -                               if (op_strategy != rc->rctype)
> -                                       elog(ERROR, "RowCompare index qualification contains wrong operator");
> -                               opfuncid = get_opfamily_proc(opfamily,
> -        op_lefttype,
> -        op_righttype,
> -        BTORDER_PROC);
>                                 * initialize the subsidiary scan key's fields appropriately
>                                ScanKeyEntryInitialize(this_sub_key,
> --- 911,923 ----
>                                        n_runtime_keys++;
> Index: src/include/nodes/execnodes.h
> RCS file: /cvsroot/pgsql/src/include/nodes/execnodes.h,v
> retrieving revision 1.206
> diff -c -r1.206 execnodes.h
> *** src/include/nodes/execnodes.h       6 Aug 2009 20:44:31 -0000       1.206
> --- src/include/nodes/execnodes.h       15 Aug 2009 04:28:55 -0000
> *** 1084,1089 ****
> --- 1084,1090 ----
>        ScanKey         scan_key;               /* scankey to put value into */
>        ExprState  *key_expr;           /* expr to evaluate to get value */
> +       bool            key_toastable;  /* is expr's result a toastable datatype? */
>  } IndexRuntimeKeyInfo;
>  typedef struct
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
